[MariaDB] MariaDB+phpMyAdmin MySQL Server Fork
sanctimon
Re: [MariaDB][10.4.22.0]MariaDB+phpMyAdmin MySQL Server Fork
Post by sanctimon »
Also, how do you restart this?
You can edit it from the menu Configurations files
sanctimon wrote: ↑03 Dec 2021, 03:02 Also, how do you restart this?
From application control (stop, start)
If you edit any of the configuration file, the app is restarted automatically
sanctimon
Post by sanctimon »
For some reason I don't have the icon on the TOS desktop. (see attachment). Perhaps it will show once I restart TOS?
I was able to restart it through /etc/init.d/MariaDB reload.
When I did so, however, I got the error:
cat: /mnt/appdata/MariaDB_DB/mysqld.pid: No such file or directory
I checked and the file is actually there, so not sure what the issue is (the file is blank, by the way).
You can access the WebUI at
http(s)://yournasip:port/modules/MariaDB/www
If the icon is missing on your desktop, you have closed the installation window before the icon was created.
Reinstall the app and when is done, wait about 5-10 sec before closing the window or after you see the icon was created.
This is a TOS issues because is not creating a message when the installation is really finished
sanctimon
Post by sanctimon »
Will Reinstalling the app recreate all the set up files and overwrite any dbs?
Normally not, DB and config files are stored outside the installation folder
sanctimon
Post by sanctimon »
Just reinstalled - the my.cnf file got overwritten. Checking for the others.
sanctimon
Post by sanctimon »
Root password - or lack thereof - was also reset to nothing.
