[ModBase1] Common libraries and tools for use by other modules
Re: [ModBase1][1.00.11] Common libraries and tools for use by other modules
up to 1.00.11 - added e2fsprogs-1.46.4
ViliamVolosV
Post by ViliamVolosV »
Hi man.You doin God job for this community.
Im new here. I have new f2-210, i far as know its arm architecture.
i wana help you with packets for arm. can we talk some how about it ?
Hardfecx
Post by Hardfecx »
{L_BUTTON_AT}outkastm
I Have a F4-210 with 4x2 TB in Raid5 ant that as is backeup up to 2 3 TB USB Drives.
Si I can help too to get more arm versions...
ViliamVolosV
Can we help you with ARM ?
added arm version 1.00.00
RedCraft
Post by RedCraft »
Hello, the arm v.1.00.00 installs 100%, but when you run it gets a lot of errors
f2-210
download again and reinstall the app
RedCraft
Post by RedCraft »
Thank you for the fixed version for arm processors, but I can't install it. My TOS 4.2.17 have crash web interface and I had to re installed the web interface TOS 4.2.15 as default, to log in. ;) I had to re install all applications that were installed, PLEX, qbittorent..Some of the new packages couldn't be installed, probably because of old files that prevented me from installing the new applications. :cry: I can't test unfortunately how to install the package "Common libraries". Probably something is preventing its install.
Unfortunately, I can't completely reinstall TOS, a lot of needed information :o I hope there is another person here on the forum who can check how the fixed package works on the arm processor.
Happy New Year!
f2-210
The .tpk packages should not interfer in any way with the TOS file system. They are using independent cross compiled libraries installed outside the TOS system. At least the installation should go smothly but eventually the application cannot start.
But as i said, without a NAS, is difficult for me to test them 100%
Pavulon
Post by Pavulon »
RedCraft wrote: 03 Jan 2022, 05:03 I hope there is another person here on the forum who can check how the fixed package works on the arm processor.
Works fine here
F2-210
