[ Radarr ] Fork of Sonarr for Movies
Re: [ Radarr ][ 4.1.0.6095 ] Fork of Sonarr for Movies
up to 4.1.0.6095
Re: [ Radarr ][ 4.1.0.6175.0] Fork of Sonarr for Movies
up to 4.1.0.6175.0
lthirion
Re: [ Radarr ][ 4.0.4.5909.0 ] Fork of Sonarr for Movies
Post by lthirion »
mrorange26 wrote: ↑13 Mar 2022, 18:20 Radarr is running but when i click on webpage link its not there.Say cannot connect.
I have got sonarr and sabnzb to work.
Do i need to install anything else.
I had a similar issue and I figured out that the problem is with the link in "Click for Web Interface to access complete HTTPS Web Interface (:7878)"
When you first start Radarr, you probably don't have SSL certs set up yet, so you get an error if you try to connect via HTTPS however, you can connect just fine with HTTP. So, change https://yournasip:7878 to http://yournasip:7878
PriestyUK
Post by PriestyUK »
Hey Outkast hope your well is there any updates coming for Radarr & Sonnarr?
Re: [ Radarr ] Fork of Sonarr for Movies
up to 4.2.4.6635.0 and added TOS5 version
PriestyUK
Post by PriestyUK »
Image :(
It seems that TOS4 cannot handle the installation of tpk files with white space in their filename.
Just rename the file (remove the white space) and try to install it again
updated
jhalfhide
Post by jhalfhide »
{L_BUTTON_AT}outkastm
Having issues with Radarr at the moment. Application stopped. Will not enable (Operation Failed). Installed latest version, same issue. Performed uninstall and reinstall. No change. Won't enable.
F2-422 running TOS 5.1
Plex/Sonarr/Radarr/Lidarr/SabNZBD
What is your TOS version?
