Connect to Actice Directory
Re: Connect to Actice Directory
{L_BUTTON_AT}thefoxes
Hi, You can try to download this compressed package: http://dl.terra-master.com/cn/AD_domain.zip(Right-click and select "Open this link in a new tab") Then decompress the compressed package. After decompression, follow the operation steps in the text document inside. If it is not resolved, please contact us.
thefoxes
Post by thefoxes »
Hi
Thanks for this
I have tried it and no it still will not connect to the AD domain .
Oddly it not takes a little longer to say "operation failed"
Can I ask is there any files /folders that are placed on the NAS when it connects to an AD Domain. As before the update I did have it connected ( i do remember it taking a number of attempts though, and cant remember if i changed the nsswitch.conf file) so my thinking could I delete these files to there is no remnants of it being connected before and then retry
Is it possible to let our engineer check it remotely? You can send an email to our tech team .
thefoxes
Re: Connect to Active Directory
Post by thefoxes »
Hi there
I am sorry i cant do that :(
My further thoughts is it anything to do with IPV6 . On windows machines sometimes this causes issues when adding to active directory. However looking at the ipv6 setting you don't get the option to "disable" , this is "close" , "auto" , "manual" and "4to6". is "closed" referring to disabled , if so the IPV6 address is still present with the network card details .
could we force the NAS box to disable it?
ThoHe
Post by ThoHe »
Sorry,
Your engineer checked it remotely for over 2 hours, and said the problem is the active-directory server, that doesn't accept php. This statement surprises me very much, since the data is transmitted over network, and a programming language should not play any role here. I have now bought a Synology and there were no problems with the connection what so ever. I have returned the TerraMaster-Nas now.
