Container has no network
Discussion about Docker
TMS
Re: Container has no network
Post by TMS »
{L_BUTTON_AT}mukmuk
It looks like multiple networks are needed and need to be verified. Have you succeeded?
mukmuk
Post by mukmuk »
Yes, it's working now. Traefik is exposed to :80 and :443 and receives the request. It'll forward the request to other containers based on the domain name, that have been activated by docker-compose labels.
So the structure is:
- disable jumpd in /etc/nasips.ini to deactivate the redirect from :80 / :443 to the TOS admin. "service S99nasips restart".
- create a docker bridge called web
- install traefik by docker-compose having:
services:
  traefik:
    [among other options]
    networks:
      - "web"
networks:
  web:
    external: true
- start traefik by "docker-compose up -d"
- get network info: "docker network inspect web"
- check "ip route list" and "ip a" for the created bridge-interface
- adjust the route for the bridge-interface to the ip range of the "web" bridge
- add the gateway ip to the bridge-interface
For a quick test you should be able to ping the traefik ip from your host. If docker created a bridge inside 172.18.0.0/16 you should be able to ping 172.18.0.2 from the host/NAS.
After that I can add any docker container to the network and interconnect it with Traefik by the docker-compose labels. So after that I've installed nextcloud via docker-compose. Traefik gets a notification and pulls a lets-encrypt cert. As soon as the nextcloud setup is done, the container is reachable by entering the domain name in browser.
mukmuk
Post by mukmuk »
Meh. Post editing ended again. :D
What I've forgotten to mention is, that the mariadb container for nextclound is running inside its own internal network. It's specified in the docker-compose.yml file of nextcloud:
networks:
  web:
    external: true # use the externally created web bridge
  internal:
    internal: true # create a new internal network only for this docker-compose project
services:
  app:
    networks:
      - web
      - internal
  db:
    networks:
      - internal
The final setup looks like the sketch in my previous posts.
TMS
Post by TMS »
Good!
mukmuk
Post by mukmuk »
If anyone is interested in the final setup, I've written two tutorials about it:
Docker network + Traefik:
https://blog.mukmuk.eu/2021/docker-reve ... on-f2-221/
Nextcloud:
https://blog.mukmuk.eu/2021/installing- ... on-f2-221/
nygage
Post by nygage »
mukmuk wrote: ↑13 Jan 2021, 16:39 I'm aware of the 169-range. As soon as the container starts, the bridge gets routed over this subnet. But only when the first container starts...
# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.178.1   0.0.0.0         UG    0      0        0 eth0
172.17.0.0      0.0.0.0         255.255.0.0     U     0      0        0 docker0
192.168.178.0   0.0.0.0         255.255.255.0   U     0      0        0 eth0
# docker network create heymatt
acfe7629b9c70b38429a8ab972c2cc53d520c17c432130f7740e1fb5b9e1a799
# docker network ls
NETWORK ID          NAME                DRIVER              SCOPE
c9ad54e42073        bridge              bridge              local
acfe7629b9c7        heymatt             bridge              local
83ec6ae8033b        host                host                local
61ee2316d6d1        none                null                local
# route -n
172.18.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-acfe7629b9c7
--- fine up to here ---
second shell: # docker run --rm -it --name debian4 --network heymatt debian:buster
first shell: # route -n
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 br-acfe7629b9c7
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 vethaf32b60
# ip route list
default via 192.168.178.1 dev eth0 src 192.168.178.36
169.254.0.0/16 dev br-acfe7629b9c7 proto kernel scope link src 169.254.251.125
169.254.0.0/16 dev vethaf32b60 proto kernel scope link src 169.254.251.81
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
192.168.178.0/24 dev eth0 scope link src 192.168.178.36
Modifying the route as well as the interface of br-acfe7629b9c7 to the docker assigned subnet 172.18.0.0/16 seem to work fine.
I've the same problem, how have you fixed It?
Thanks!
mukmuk
Post by mukmuk »
nygage wrote: ↑31 Jan 2021, 23:47 I've the same problem, how have you fixed It?
Thanks!
Hey nygage,
yup, I've solved it. You can find more infos in my blog post under: https://blog.mukmuk.eu/2021/docker-reve ... on-f2-221/
The interesting part comes at "Changing the network interface and routes". As well as here: https://blog.mukmuk.eu/2021/docker-0-me-1/
nygage
Post by nygage »
I saw it thanks! But after reboot, how do you automate it?
mukmuk
Post by mukmuk »
I haven't set up any automation for now. Just form the theory of it, it should be enough having a service after reboot, which sets the route + ip to the interface. If I find the time in the next few days, I might post a tutorial for it.
Terra_User123
Post by Terra_User123 »
Hello guys,
I find it very inconvenient to change jumpd to NO every reboot, so I created a script to fully automate disabling the nasips.ini / setting jumpd = YES to NO after reboot, follow steps below:
1. SSH to TNAS as root
2. cd /etc
3. cd crontabs
4. vi root
5. add the following to the crontabs config:
@reboot cd /etc ; sed -i '2s/^.*$/jumpd = NO/' nasips.ini ; service S99nasips restart
6. press ESC then :wq
This should disable redirect after every reboot! Reboot TNAS and check if it worked.
This is also very important to deactivate because when jumpd is set to YES, it makes a redirection to the local nas even though I only talk to the CPE router with a Port on my nas. I do not see any use of this redirect function!
Return to “Docker”
