Nextcloud over the internet?
kteach
Re: Nextcloud over the internet?
Post by kteach »
This is something I need to do. However, I cannot find the proper config.php. I did find one here:
/mnt/md0/application/web-ext/nextcloud/config/config.php
However, the file is completely blank.
I then, with the help of a tech support from Terramaster found two other potential places. However, both places did not contain a config.php file
/usr/local/pkgs/nextcloud/usr/www/nextcloud/config
"no config.php" file
/usr/local/pkgs/nextcloud/usr/local/web-ext/nextcloud/config/
Does anyone else know where I might find the active config.php for the nextcloud install? This is the default install offered by Terramaster in "applications". Thank you for any help!
kteach
Post by kteach »
Ah, I found my problem. I was using an Admin user to SSH into the NAS. I needed to use root. Once I did, the file shows up here for me
I hope that tip helps someone.
Return to “CloudSync”
