TOS 7.0.1652 (x86) Official Release Update
Alak
France
Re: TOS 7.0.1652 (x86) Official Release Update
Post by Alak »
Following up on my previous report regarding the Firefox password manager dropdown not appearing on the TOS 7 login screen:
Here is the exact technical reason why this happens in Firefox (unlike Chrome/Edge, which are more permissive with standalone text inputs):
1. Missing autocomplete="username" on the step-1 input: Because TOS 7 uses a two-step login flow (username first, password loaded dynamically in step 2), there is no <input type="password"> present in the DOM during step 1. Without a password field in the DOM, Firefox's autofill engine (Fathom) strictly requires the username <input> element to include the autocomplete="username" attribute (and ideally name="username" or id="username"). Currently, the step-1 text input lacks this attribute, so Firefox treats it as a generic text box rather than a login field.
2. Why it works right after a TOS update reboot: Immediately after a firmware update reboot, the initial redirect renders a state where both the username and password inputs exist in the DOM at the same time (even if the password field is visually hidden). Once the first login completes, subsequent sessions switch to the standard two-step dynamic rendering where the password <input> is absent from the DOM on step 1, breaking Firefox's autofill detection.
Suggested fix:
Simply adding autocomplete="username" to the username <input> element on the step-1 login form (or keeping the <input type="password"> hidden in the DOM during step 1, as Synology DSM and QNAP QTS do) will immediately restore native Firefox autofill support.
Thanks!
:ugeek: F4-424 :ugeek:
:ugeek: D6-320 :ugeek:
