CPU at 100%
Re: CPU at 100%
CPU reporting high usage seems to be a problem with some of the TOS updates its happened several times over various updates I have seen, it frequently yet cannot find any processes adding to that percentage of use, have a search you will find lots of post moaning about this problem.
Re: CPU at 100%
I've reinstalled the Google Drive and I'll see what I can find when it starts crashing things again.Tricky wrote: ↑04 Feb 2021, 18:50 CPU reporting high usage seems to be a problem with some of the TOS updates its happened several times over various updates I have seen, it frequently yet cannot find any processes adding to that percentage of use, have a search you will find lots of post moaning about this problem.
I have an F5-420.
Is this problem model-dependent?
Re: CPU at 100%
Mine is the F5-221 and I don't think it model dependent more software dependent as I have loaded at least three TOS versions that exhibit this behaviour the main CPU/memory display does not report the true usage.
Re: CPU at 100%
All services on the NAS have just frozen, I can't even load the TOS web interface.
When it happened the other day, i was on 4.2.08, yesterday I updated to 4.2.09, so unfortunately no change.
It's a shame, I'd like to have an easy local backup/sync solution of my Google Drive.
Re: CPU at 100%
Aaaand moments after that last post, my APs disconnected.
Once everything came back I uninstalled the Google Drive app again and no problems.
- sianderson
- Silver Member
Re: CPU at 100%
while my CPU is not at 100% it does seem to be fairly constant at over 60% with two instances of NASIPS running, can TM comment on what this process actually belongs to?
a reboot seems to have settled it down to average around 4% total, and theres just one instance running that isnt consuming the cpu
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Re: CPU at 100%
{L_BUTTON_AT}justsimon
Is it possible to let our engineer check it remotely? You can send an email to our tech team:viewtopic.php?f=75&t=608To contact our team, please send email to following addresses, remember to replace (at) with @
Re: CPU at 100%
Hi Ryan,
It is possible.
Though have you done any testing in-house yet?
If one of you set it up on a test NAS, I'd have thought you'd see the same issue.
It is possible.
Re: CPU at 100%
Hi, Justsimon
We will try.
I believe the technicians will find out the reason after remote for you.
We will try.
