Regarding the ntpd issue, we will vafiry it soon, thank you for your report.
TOS 7.0.1105 (x86) Official Release Update
Re: TOS 7.0.1105 (x86) Official Release Update
- sianderson
- Silver Member
both updated, no issues observed so far
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Update: After restarting the GlobalSearch service, the high CPU usage stopped.nitzer71 wrote: ↑05 Aug 2026, 12:55 After upgrading to TOS 7.0.1105, I noticed that the GlobalSearch process has been running continuously for several hours and using around 120–150% CPU.
Media Indexing is disabled on my TNAS.
I noticed the release notes mention a fix related to media indexing and system drive sleep mode. Could this update have triggered a GlobalSearch rebuild or some indexing process after the upgrade?
I did not notice this behaviour after the previous TOS 7 update, so I just wanted to check if this is expected.
Before the restart,
globalsearchAfter restarting the GlobalSearch service, CPU usage returned to normal and the service is now idle.
I will continue monitoring.
F4-425 Plus | 16GB RAM | Intel(R) N150 | 3× 12TB HDD (TRAID) | 1× 1TB NVMe | 1× 500GB NVMe
So disk sleep activity has changed but not for the better. Now both HDDs sleep for 30 minutes, wake up together then go back to sleep after another 30 minutes, wake up after 30 minutes, etc....
This activity is preceded by SMART reports of temperature changes for the two drives but the temperatures reported are between 50C and 65C which are the temps of the M.2 drives; the HDDs are between 30C and 35C. These SMART reports are not present in the system log I recorded with TOS 7.0.0804.
Aug 5 01:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 63
Aug 5 01:55:12 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60
Aug 5 01:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 01:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
Aug 5 02:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 55
Aug 5 02:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52
Aug 5 02:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby
Aug 5 02:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby
Aug 5 02:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 63
Aug 5 02:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60
Aug 5 02:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 02:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
Aug 5 03:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 55
Aug 5 03:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52
Aug 5 03:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby
Aug 5 03:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby
Aug 5 03:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 63
Aug 5 03:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60
Aug 5 03:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 03:55:22 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
Aug 5 04:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56
Aug 5 04:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52
Aug 5 04:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby
Aug 5 04:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby
Aug 5 04:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63
Aug 5 04:55:12 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60
Aug 5 04:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 04:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
Aug 5 05:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56
Aug 5 05:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52
Aug 5 05:26:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby
Aug 5 05:26:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby
Aug 5 05:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63
Aug 5 05:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60
Aug 5 05:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 05:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
Aug 5 06:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56
Aug 5 06:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 53
Aug 5 06:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby
Aug 5 06:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby
Aug 5 06:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63
Aug 5 06:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 60
Aug 5 06:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 06:55:22 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
Aug 5 07:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56
Aug 5 07:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52
Aug 5 07:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby
Aug 5 07:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby
Aug 5 07:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63
Aug 5 07:55:12 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60
Aug 5 07:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm
Aug 5 07:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
F2-425 Plus (N150), 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.1 beta
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
Thx snapsh0t, its exact the same on both of my NASsnapsh0t wrote: ↑05 Aug 2026, 16:15 So disk sleep activity has changed but not for the better. Now both HDDs sleep for 30 minutes, wake up together then go back to sleep after another 30 minutes, wake up after 30 minutes, etc....
Aug 5 01:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 63 Aug 5 01:55:12 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60 Aug 5 01:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 01:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm Aug 5 02:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 55 Aug 5 02:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52 Aug 5 02:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby Aug 5 02:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby Aug 5 02:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 63 Aug 5 02:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60 Aug 5 02:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 02:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm Aug 5 03:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 55 Aug 5 03:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52 Aug 5 03:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby Aug 5 03:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby Aug 5 03:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 55 to 63 Aug 5 03:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60 Aug 5 03:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 03:55:22 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm Aug 5 04:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56 Aug 5 04:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52 Aug 5 04:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby Aug 5 04:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby Aug 5 04:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63 Aug 5 04:55:12 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60 Aug 5 04:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 04:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm Aug 5 05:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56 Aug 5 05:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52 Aug 5 05:26:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby Aug 5 05:26:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby Aug 5 05:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63 Aug 5 05:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60 Aug 5 05:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 05:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm Aug 5 06:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56 Aug 5 06:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 53 Aug 5 06:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby Aug 5 06:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby Aug 5 06:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63 Aug 5 06:55:13 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 53 to 60 Aug 5 06:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 06:55:22 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm Aug 5 07:25:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 63 to 56 Aug 5 07:25:04 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 60 to 52 Aug 5 07:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=active to=standby Aug 5 07:25:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=active to=standby Aug 5 07:55:04 Therver2 smartd[14563]: Device: /dev/sda [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 56 to 63 Aug 5 07:55:12 Therver2 smartd[14563]: Device: /dev/sdb [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 52 to 60 Aug 5 07:55:17 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sda from=standby to=active detected_by=hdparm Aug 5 07:55:21 Therver2 TOSDaemon[16071]: disk power state changed device=/dev/sdb from=standby to=active detected_by=hdparm
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
You can check the status of both services with the following commands:
systemctl status smartd.serviceCode: Select all
systemctl status smartmontools.serviceCode: Select all
systemctl stop smartd.serviceCode: Select all
systemctl disable smartd.serviceTo contact our team, please send email to following addresses, remember to replace (at) with @
Does update to .1105 rewrite the usb initboot to be compatible with TOS7 (ie default boot to TOS7) without following the older procedure.
Frustrated Beta Tester!!!
Please note that upgrading or updating TOS 7 will not overwrite the USB Initboot.
So if you need to reinstall the TOS 7, you'll have to manually flash the USB Initboot to the TOS 7‑specific version.
viewtopic.php?t=6433
After upgrading to TOS 7.0.1105, I noticed the globalsearch service eventually starts consuming around 120–150% CPU continuously. Restarting the GlobalSearch service temporarily resolves it, but the issue returns after several hours. The only indexed directory configured is the default user home folder, which contains only 17 files (~132 KB). Media Indexing is disabled.
Update: I restarted the GlobalSearch service and CPU usage dropped back to normal, but after several hours the issue returned.nitzer71 wrote: ↑06 Aug 2026, 09:49 After upgrading to TOS 7.0.1105, I noticed the globalsearch service eventually starts consuming around 120–150% CPU continuously. Restarting the GlobalSearch service temporarily resolves it, but the issue returns after several hours. The only indexed directory configured is the default user home folder, which contains only 17 files (~132 KB). Media Indexing is disabled.
The configured indexed directory is only the default user home folder and shows "Completed". The GlobalSearch database remains only 32 KB.
I checked the process and it appears to have a fanotify filesystem watcher open. During high CPU usage, strace shows repeated failed reads:
read(8, ..., 256) = -1 EINVAL (Invalid argument)This seems more like a GlobalSearch filesystem watcher loop than a normal indexing operation. Could this be related to the TOS 7.0.1105 update?
