[Help] Anyone succeeding creating a VM with Windows ?
EriChan
Re: [Help] Anyone succeeding creating a VM with Windows ?
Post by EriChan »
petrose wrote: ↑22 Aug 2026, 22:20
We appreciate your response.
At your earliest convenience, may we ask for the precise model of your Google router? This will help us follow up on the situation and attempt to reproduce the problem in our test environment.
petrose
Denmark
Post by petrose »
TMzethar wrote: ↑31 Jul 2026, 08:46 Hi.
VirtualBox is currently available for installation via the App Center.
Additionally, PHP 7.4, which you noted as missing, is also available there if you need it.
As for the virtual machine network adapter issue you mentioned — especially the problem where USB network adapters cannot be used — we will conduct verification and further investigation.
Well, as I notified in the TOS7 forum a few months back, the PHP74 fails during install when near 20%.
My TNAS version is upgraded to 7.0.1169 but the issue persist.
The following excerpt is from syslog:
Sep 10 17:21:59 SonjaNAS application[15883]: DEBUG /bin/bash -c btrfs subvolume create "/Volume1/@apps"
Sep 10 17:21:59 SonjaNAS application[15883]: DEBUG /bin/bash -c btrfs subvolume create "/Volume1/@cache"
Sep 10 17:21:59 SonjaNAS application[15883]: [GIN] 2026/09/10 - 17:21:59 | 200 |   22.090918ms |                 | GET      "/app/setting"
Sep 10 17:22:00 SonjaNAS application[15883]: [GIN] 2026/09/10 - 17:22:00 | 200 |      63.464µs |                 | GET      "/app/index/js/chunk.chunk-3d3a5c1c.js?v=1786521708130"
Sep 10 17:22:06 SonjaNAS application[15883]: [GIN] 2026/09/10 - 17:22:06 | 200 |    1.726845ms |                 | POST     "/app/install"
Sep 10 17:22:06 SonjaNAS application[15883]: DEBUG /usr/bin/systemctl disable PHP74
Sep 10 17:22:06 SonjaNAS application[15883]: Shell execute error. Error=Failed to disable unit: Unit file PHP74.service does not exist.#012: exit status 1
Sep 10 17:22:06 SonjaNAS application[48635]: E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
Sep 10 17:22:06 SonjaNAS application[15883]: Application install failed:install error
Sep 10 17:22:07 SonjaNAS application[15883]: App operation error. AppID=PHP74 Operate=install Error State=2
Sep 10 17:22:07 SonjaNAS application[15883]: App state will be deleted. AppID=PHP74
BR PetRose
My TNAS: F8 SSD Plus, now with TOS7 Final version along with 1+3x2 TB SSD sticks, formatted as BTRFS and using TRAID
petrose wrote: ↑11 Sep 2026, 00:36
Based on the logs, the PHP74 installation failed because the system’s dpkg package management process was previously interrupted, preventing the installation from continuing.
The message PHP74.service does not exist indicates that the PHP74 service had not yet been created when the installation process attempted to disable it. This is not the main cause of the installation failure.
Please connect to the NAS via SSH and run the following command to complete any pending package configuration:
dpkg --configure -a
Then try installing PHP74 again.
If dpkg --configure -a returns any errors, please provide the complete output to us. This will help us identify which package caused the `dpkg` process to become interrupted and investigate the issue further.
Return to “Virtual Machines”
