TOS 4.2.06 is released for update!
sianderson
Re: TOS 4.2.06 is released for update!
Post by sianderson »
TMSupport wrote: 10 Nov 2020, 18:04 The huge icon is appeared on TOS4.2.06?
yes this on 4.2.06
F2-424 TOS 7.0.1169
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
sianderson
TMroy wrote: 10 Nov 2020, 18:09
yerc1 wrote: 10 Nov 2020, 18:07
Yes those huge icons are on TOS 4.2.06.
Clean your browser cache after update.
perfect thank you, other icons have also changed now :)
F2-424 TOS 7.0.1169
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
yerc1
Post by yerc1 »
Yes that fixed the huge icons.
F2-221
Ryzen
Post by Ryzen »
Hello
Can you help me ? For me remains blocked when the software is unzipped
When i look in SSH this process start but stop after few seconds :
and disks stop working
I am on F2-210 in 4.1.32
F2-210
4.2.06
Ryzen wrote: 10 Nov 2020, 18:30 Can you help me ? For me remains blocked when the software is unzipped
The update package does not need to be unzipped.
Ryzen
Post by Ryzen »
TMroy wrote: 10 Nov 2020, 18:39
I know, I'm not unzipped it. It's the process that does it. It's just to tell you when it blocks :
F2-210
4.2.06
Tricky
Post by Tricky »
Can you explain what this actually means?
3. Canceled the feature of uploading documents to TOS desktop;?
I have seen the odd oversize effects that some are getting on one of the previous beta versions, i have been running the 4.1.30 version which works reasonably well aside from not restarting after a power cut, a friend has been running the beta 4.2.02 for some time without problems so far and i am reluctant to change as it usually brings problems with it
Ryzen
Post by Ryzen »
Ryzen wrote: 10 Nov 2020, 18:45
To complete, sometimes I have this message (once in two) : Download fail
I downloaded the source file several times
F2-210
4.2.06
sports_wook
Re: TOS4.2.06 is released for update!
Post by sports_wook »
sports_wook wrote: 10 Nov 2020, 12:46
sports_wook wrote: 10 Nov 2020, 12:11 F2-220 on 4.2.05 - getting error "Update package is not correct!!!". And yes, I am using the x86 version, not ARM (which my system does not support).
Nevermind just noticed this in the release notes - "this update is only suitable for TOS 4.1.27 or above".
So how do I update from 4.2.05? Seems like there are bug fixes in this version that patch issues I'm experiencing on 4.2.05, but I can't update with this file.
Ok the issue from my last post only occurred when I access the system from https port. The http port does not give this issue, however it just hangs on "unzipping the software package" and never completes, then the page eventually reloads and system is still on 4.2.05 (when applying update through http port, not https).
Ryzen
Post by Ryzen »
sports_wook wrote: 10 Nov 2020, 20:09
Thanks but got same problem
I can see in ssh the decompression work that the NAS is doing but it stops after a few seconds :
F2-210
4.2.06
