How to Properly Install and Use TOS 7 on the 424 Series TNAS
AlexNo
Re: How to Properly Install and Use TOS 7 on the 424 Series TNAS
Post by AlexNo »
Hi!
I have a F4-424 Pro 32 Gb model. Only HDD. BIOS: MADN0101.V07.
When TOS 7 was tested, the system automatically installed TOS 6 for me, and then I updated it to the beta version of TOS 7. Since the system has been released, I would like to install TOS 7 from scratch.
If I update my BIOS to version MADN0101.V08, will I be able to install TOS 7 directly, bypassing the installation of TOS 6?
F4-424 Pro: 32GB RAM | BIOS: MADN0101.V07 | TOS v 7.0.0777
AlexNo wrote: 25 Jun 2026, 16:22 I would like to install TOS 7 from scratch.
Wouldn't that be nice - this year, next year, sometime ...... you know how it goes.
MikeZhang
Post by MikeZhang »
We will release the necessary documents as soon as possible; if you are not in a rush, please wait patiently.
Or you can follow our instruction to have TOS7
AlexNo
Post by AlexNo »
MikeZhang wrote: 25 Jun 2026, 17:02
Thanks for the reply. I'll wait :)
Podrez
Moldova
Post by Podrez »
Gremlin wrote: 25 Jun 2026, 03:39
No — nothing worked.
We spent the whole day with support trying to restore TOS6 and upgrade to TOS7. We figured out the USB drive issue; it’s not important right now. I reinstalled TOS and tried installing it on different SSDs, but nothing helped.
All for nothing.
Even after updating and unpacking TOS7, the system still boots into TOS6.
There are no errors or freezes during the update. I don’t understand why the upgrade has to be so painful.
Tony92
Post by Tony92 »
I was not on the impacted BIOS version, yet after installing TOS7 I am still being prompted to initialize
F4-424 Pro: 4Bay Core i3-N305 8-Core 8-Thread CPU, 32GB DDR5 RAM | TRAID Pool 1 (18TBx18TBx18TBx4TB SATA HDDs) | TRAID Pool 2 (Two Samsung 980 NVMe M.2 1TB/ea)
D8 Hybrid attached: Single Disk (12TB SATA HDD)
DCCentR
Post by DCCentR »
I am on 7.0.0746 already and my BIOS is MADN0101.V05
Should i update BIOS to MADN0101.V08?
Is there a list of changes for MADN0101.V05 to MADN0101.V08?
I'd also like to see a package for a clean installation of TOS7.
F4-424 Pro
MikeZhang
Post by MikeZhang »
DCCentR wrote: 26 Jun 2026, 02:58
Your BIOS version is not among the versions mentioned in the post, so you can update normally.
Don't need any extra setting.
I have an F2-424 currently running Bios MADN0101.V05.
While I realise (now*) that this version does NOT require a Bios update to function "normally" I am seeking clarification
as to whether there is anything detrimental in applying the "latest" bios update (MADN0101.V08).
Like many I usually subscribe to the school of "If it ain't broke don't fix it". However, I know there are many who prefer the "latest of it's kind".
Some clarification of what might be different in the later Bios version would be greatly appreciated.
*I will admit to confusion between the bios numbers of the -424 and -425 on reading the relevant posts and fixating on the V## ;)
MikeZhang
Post by MikeZhang »
Podrez wrote: 25 Jun 2026, 20:19
But later on you have succeeded with the other SSD 1TB
Migration system to smaller drive is not supported
