CloudSync  [Accepted]
rfbjr
Re: CloudSync
Post by rfbjr »
Gremlin wrote: ↑23 Jun 2026, 18:07
MikeZhang wrote: ↑23 Jun 2026, 16:19
rfbjr wrote: ↑23 Jun 2026, 08:53
your thought has been recorded
@rfbjr
You see - they are now recording your thoughts :lol: {I'll credit you with more than one :idea: }
:lol:
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
MikeZhang
Re: CloudSync
Post by MikeZhang »
Please describe your requirements in detail. When creating a task, there's a default polling time. If you don't change the polling time, there won't be any issues.
rfbjr
Re: CloudSync
Post by rfbjr »
When creating a task, you fill in all the fields you need, my specific problem was the default poling is 5min (or whatever the default is). So if I don't change that, the next screen creates the task and starts the job. I'm asking for is one more screen which recaps the data you enter. On that recap screen the next button would then create the task but also gives you a back button so you could the go back to correct something.
EDIT: When I have had more coffee, I'll find some other program/task that gives you the recap before the job/task is create. I know there are, that is what gave me the idea.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
Re: CloudSync
rfbjr wrote: ↑08 Jul 2026, 18:29
Thank you for your advice. We will list it on our features wanted list.
rfbjr
Re: CloudSync
Post by rfbjr »
Thank you, the latest update to CloudSync, I now see the next polling time for each task.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
