This could be an important issue worth looking into. Could you please let us know which NAS model you are experiencing this problem on?
Motherboard Stand-by
Re: Motherboard Stand-by
I was testing suspend on a F2-425+. (Silly me)
I have now done some more testing and I believe my issue may be within TNAS-PC or a combination.
I also have F2-424 - when looking at Tnas-PC I realise that in the "Access History" I see entries for 2 Bond connections plus an entry for LAN1 with the same IP address. This allows me to activate WOL successfully. I can also utilise a 3rd party app ok.
The 425+ has this issue - viewtopic.php?p=58331#p58331
such that in Tnas-PC I see a single Bond connection and the "errant" LAN1 at 169.254.0.0. THIS does not work.
All of which leads to another question of what should I actually be seeing in Tnas-PC? (In addition why does Tnas-PC not display the MAC address in Access History?)
Sorry this has gone a bit off topic.
Frustrated Beta Tester!!!
Thank you for your suggestion! It's a very practical idea. However, this feature cannot be easily addressed through software alone. Unlike a PC, which can be woken up via physical buttons, a NAS is typically a remote device. Implementing full-system sleep would require a separate wake-up mechanism, possibly even hardware modifications. We will discuss this internally and keep you posted if there are any developments. Thank you!
