DigitalAnalog
Australia
Post by DigitalAnalog »
TMroy wrote: 30 Jul 2024, 09:53
usersky wrote: 29 Jul 2024, 16:44
If you don't know what it means to replace the root file system, let me tell you this way: Due to the replacement of the root file system, almost all library files of TOS have been replaced, almost all components have been updated, all interfaces have been adapted, plus the improvement and optimization of the UI. There are more than 2000 items modified in total, so TOS 6.0.420 is a completely new beta version. Are you sure you need to know all these items on a list?
Hi, ASUSTOR, QNAP and Synology have zero problems writing and publishing release notes for their NAS software showing new features and issues fixed. Why should your software be any different?
F4-423
imranalam
Pakistan
Post by imranalam »
my TNAS model is F4-223, I am unable to use remote access after updating to TOS 6, device registration done, remote access service enabled logged in, when i try to access with my TNAS id it display error not found.
even tnas.online shows id does not exist.
usersky
Romania
Post by usersky »
Gremlin wrote: 29 Jul 2024, 16:49
If you have been "in software development for ever", what don't you understand about BETA?
There is nothing not understand about a beta version, what I don't understand is that an "update" comes with "we cannot say what is new (or changed) because everything is new". That simple, this is not how you deliver an update (beta included). Maybe sometimes in extreme cases you may be totally lost in what impact some sh*t you did may have, even then you can come with some explanation so that your customers won't get under the impression that you totally lost the control of the project. Moreover, blaming customer for not understanding such a failure is insulting.
You didn't understand what I wrote (just joking! ;)
usersky
Romania
Post by usersky »
No, I found enough to just stay away thank you. Have fun testing 2000 items changed!
golgoth
Italy
Post by golgoth »
golgoth wrote: 29 Jul 2024, 04:52 No more EU/US choice for tnas online?
Any official statement about this?
imranalam
Pakistan
Post by imranalam »
TMroy wrote: 30 Jul 2024, 09:55
at www.tnas.online when i enter newly register id after updating to TOS6.x.x420, it gives error "This id doesn't exist"
but when i enter old id at www.tnas.online it doesn't give id not exist error but shows to new white screen and first line says "Not Found"
this is my whole experience in last few days, please tell me how to rectify so I will be to use Remote Access.
Imran Alam
IdiotBox
Post by IdiotBox »
After the update I can't access third-party applications
What do I need to do to get the apps working again? Login as admin
golgoth wrote: 30 Jul 2024, 23:04
You no longer need to manually select a server. The system will automatically choose the optimal route for you based on the current server load.
IdiotBox wrote: 31 Jul 2024, 04:54
Third party application need to be updated to TOS 6 compatible version.
imranalam wrote: 30 Jul 2024, 23:15
Rename your TNAS ID and try again.
