[ qBittorrent + CLI ] An open-source software alternative to µTorrent
About : https://www.qbittorrent.org
Applicable models: x.64 series, ARMv8 series, ARMv8.2 series
Applicable TOS6: 6.0.420 or later versions
Applicable TOS7: 7.0.0130 or later versions
App download: https://tmnascommunity.eu/download/qbittorrent
Required packages:
Python311 - If you want to use the latest search plugins (Only for x.64)
Include CLI
https://github.com/fedarovich/qbittorre ... ng-Started
About:
qBittorrent Features
Polished µTorrent-like User Interface
No Ads
Well-integrated and extensible Search Engine
Simultaneous search in many Torrent search sites
Category-specific search requests (e.g. Books, Music, Software)
RSS feed support with advanced download filters (incl. regex)
Many Bittorrent extensions supported:
Magnet links
Distributed hash table (DHT), peer exchange protocol (PEX), local peer discovery (LSD)
Private torrents
Encrypted connections
and many more...
Remote control through Web user interface, written with AJAX
Nearly identical to the regular GUI
Sequential downloading (Download in order)
Advanced control over torrents, trackers and peers
Torrents queueing and prioritizing
Torrent content selection and prioritizing
Bandwidth scheduler
Torrent creation tool
IP Filtering (eMule & PeerGuardian format compatible)
IPv6 compliant
UPnP / NAT-PMP port forwarding support
Available in ~70 languages
Re: [ qBittorrent + CLI ][4.3.3.0] An open-source software alternative to µTorrent
added initial version 4.3.3.0
Re: [ qBittorrent + CLI ][4.3.3.1] An open-source software alternative to µTorrent
added armv8 version. Not tested so post here if is working
onemeshnig
Post by onemeshnig »
Installed armv8 version on f4-210, trying login with admin admin, but:
(W) 2021-04-15T00:26:32 - WebAPI login failure. Reason: invalid credentials, attempt count: 1, IP: ::ffff:192.168.1.189, username: admin
(W) 2021-04-15T00:26:59 - WebAPI login failure. Reason: invalid credentials, attempt count: 2, IP: ::ffff:192.168.1.189, username: admin
(W) 2021-04-15T00:27:18 - WebAPI login failure. Reason: invalid credentials, attempt count: 3, IP: ::ffff:192.168.1.189, username: admin
(W) 2021-04-15T00:27:21 - WebAPI login failure. Reason: invalid credentials, attempt count: 4, IP: ::ffff:192.168.1.189, username: admin
Restart the module and try again
Username admin
For password try admin or adminadmin
onemeshnig
Re: [ qBittorrent + CLI ][4.3.5.0.0] An open-source software alternative to µTorrent
Hello! Can't install new version if system language is Russian!
onemeshnig
onemeshnig wrote: ↑14 May 2021, 01:56 Hello! Can't install new version if system language is Russian!
Sorry, my mistake - all your programs can't be installed if system language set to Russian :cry:
indeed, the first app's can be installed if the system language is set to english and some were updated to be installed if the system is set to one of the following languages:
[en-us]
[zh-cn]
[zh-hk]
[ja-jp]
[de-de]
[fr-fr]
[it-it]
[es-es]
As from now i will include the missing ones
[de-de]
[ko-kr]
[hu-hu]
[pl-pl]
[ru-ru]
[tr-tr]
