[ Tailscale ] VPN to connect your team and devices easy  [SOLVED]
Re: [ Tailscale ] VPN to connect your team and devices easy
Your TOS version is missing in description.Provide also the fullname of the tpk file installed
wsy91
Malaysia
Post by wsy91 »
outkastm wrote: 21 Jan 2026, 00:48 Your TOS version is missing in description.Provide also the fullname of the tpk file installed
TOS version: 5.1.131-00123
tpk name: Tailscale TOS5 1.92.1.0 x86_64.tpk
MacStainless
Post by MacStainless »
There's an issue with the current TOS6 version of this file. When I try to install it, I get the following error: "Error! The file is incorrect and cannot be installed."
This is the file: `Tailscale TOS6 1.94.2.0 aarch64.tpk`
Any help on why this won't install would be appreciated. Thank you.
crisisacting
Post by crisisacting »
MacStainless wrote: 24 Mar 2026, 01:40
Do you have an ARM based TNAS as the aarch64 version is only meant for the 211/212 series?
MacStainless
crisisacting wrote: 24 Mar 2026, 05:58
I have the F4-425 plus, which I'm 99% sure is intel. The versions listed for download show no x86 version for TOS6, which is very weird. HTF am I supposed to get this installed? As far as I'm aware, there's no other method of getting TailScale onto a TNAS besides this community effort.
Tailscale TOS7_TOS6 1.94.2.0 x86_64.tpk
Tailscale TOS5 1.94.2.0 x86_64.tpk
Tailscale TOS5 1.94.2.0 aarch64.tpk
Tailscale TOS7_TOS6 1.92.1.0 x86_64.tpk
Tailscale TOS6 1.92.1.0 aarch64.tpk
Tailscale TOS5 1.92.1.0 aarch64.tpk
crisisacting
MacStainless wrote: 25 Mar 2026, 01:05
have the F4-425 plus, which I'm 99% sure is intel. The versions listed for download show no x86 version for TOS6, which is very weird. HTF am supposed to get this installed? As far as am aware, there's no other method of getting TailScale onto a TNAS besides this community effort.
One of these:
The former being the newer release
MacStainless
Re: [ Tailscale ] VPN to connect your team and devices easy  [SOLVED]
crisisacting wrote: 25 Mar 2026, 06:47One of these:
Oh wow, that was it! I saw "TOS7" and my brain shut off; I didn't even look further in the filename. In my defense, I haven't come across combined OS versions of the apps before from the community site. I was just able to get the 1.94.2.0 package installed on my TNAS. THANK YOU!!!
Renzz
Israel
Post by Renzz »
After updating to TOS7 suddenly Tailscale on the Web UI giving the "502 Bad Gateway" error and i canno't find the NAS anymore even when it states that the NAS connected in the Admin console.
Any idea how to fix that?
ShowsOn
Australia
Post by ShowsOn »
Renzz wrote: 23 Jun 2026, 20:55 After updating to TOS7 suddenly Tailscale on the Web UI giving the "502 Bad Gateway" error and i canno't find the NAS anymore even when it states that the NAS connected in the Admin console.
Just confirming I have the same issue. I bought a F4-425 Plus today and upgraded it to TOS 7 (7.0.0765). I can't get Tailscale to work because of this 502 bad gateway issue. Underneath the 502 message it says "nginx/1.18.0 (Ubuntu)".
The version of Tailscale I installed is "Tailscale TOS7_TOS6 1.94.2.0 x86_64"
Edit: 10 hours later. I have managed to get Tailscale to work. The issue simply seems to be a problem with getting the web GUI to load.
Renzz
Israel
Post by Renzz »
ShowsOn wrote: 04 Jul 2026, 20:21
I've managed to get the web GUI to load by installing PHP 7.4 from the app center but even though i authorize the NAS again i am still unable to connect to it even if Tailscale shows it online.
I'm going to reset the system to see if it helps..
