How to reinstall TOS for your TNAS?
flo0306
France
Re: How to reinstall TOS for your TNAS?
Post by flo0306 »
I understood the default port for SSH is 9222 on TOS :
@Mac ~ % ssh -p 9222 [email protected]
** WARNING: connection is not using a post-quantum key exchange algorithm.
** This session may be vulnerable to "store now, decrypt later" attacks.
** The server may need to be upgraded. See https://openssh.com/pq.html
[email protected]'s password:
What is the default password ?
Felix
Post by Felix »
flo0306 wrote: ↑26 Feb 2026, 19:15 I understood the default port for SSH is 9222 on TOS :
Default password:admin
jvenard
Post by jvenard »
My F5221 board stopped working. I was told to by a F6424. The question is, what is required to move my F5 RAID drives to the F6 chassis.
Do I need to simply install the drives and power on?
Do I need to add a new drive and bring it up to speed and then add my 5 drives from my F5?
Please provide any links or knowledge on this process
Felix
Post by Felix »
jvenard wrote: ↑23 Apr 2026, 09:30
You need to confirm your original TOS version. If it's a newer version like TOS6, you can boot directly from the installation hard drive. If it's an older version, you'll need to add a new disk to install the system. We recommend scheduling a remote migration with an engineer via the official website's online chat after your new device arrives.
jvenard
Post by jvenard »
I was at 5.X tos and I insatlled my drives and it booted back to my original setup
The default boot system for the F6-424 is TOS 6. You can install TOS 6 on a new hard drive and then insert the five old hard drives to read the data. If the system on the old hard drives is functioning normally, you can also remove the internal USB drive with the bootable system and directly insert it into the old hard drive to boot the NAS.
lukx
Post by lukx »
Hi
I need some help - I have F4-220 brand new, never used . I installed 500gb hdd for now but it seams it need TOS system. When I'm installing it from the "web" can't find the server, when from file it crash on 55% . In bottom right corner I can see J1800_v4.3
How to over come this issue ?
lukx wrote: ↑15 Jul 2026, 02:57 Hi
Sorry to say the F4-220 is hardly a recent device. I think it was designed for the Tos4 era. Please see this regarding Tos4 EOL:
viewtopic.php?p=56215#p56215
and suggested Tos operating system version(s).
Further, the -220 series do not appear in the list of supported devices for Tos7 (see recent release notes).
Frustrated Beta Tester!!!
angelor
Italy
TOS7: How to downgrade to a specific version
Post by angelor »
Goodmornig,
i have F4-424pro NAS with the last BIOS and the last TOS7 version. I would like to downgrade the TOS7 at a specific version (e.g. to 7.0.1169).
How can i do? Can someone specified all the steps to achieve this?
I found on the forum a couple of message but are quite old....
Many thanks in advance.
Regards
Angelo
EriChan
Re: TOS7: How to downgrade to a specific version
Post by EriChan »
angelor wrote: ↑04 Nov 2026, 17:18
TOS does not support downgrading to an earlier version.
What specific issues or bugs are you experiencing on the latest version that require a downgrade? Please share the details so we can help troubleshoot and resolve them.
