SSD Compatibility List (will be continuously updated)
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
ltoynbee
Re: SSD Compatibility List (will be continuously updated)
Post by ltoynbee »
I bought a new SABRENT 1TB Rocket NVMe 4.0 Gen4, and configured it as Hyper Cache in my F2-423. However, during extended write operations, the NAS throws alarms that it is overheating. Has anyone had issues with this? I’m guessing because it’s “on the list”, it wouldn’t be a compatibility issue? I think my next step will be to throw the drive in an enclosure and test extended write sessions on it, before deciding if it’s a bad drive. Just curious if anyone has seen this. I’ve never had an NVMe drive overheat before.
-Thanks
{L_BUTTON_AT}ltoynbee
Please check whether the fan of the device is running normally? Check the temperature of the hard disk and device in the control panel - system info - overview.
RedCraft
Post by RedCraft »
Hello, I tested
SSD Apacer AS340 120 Gb
( SM2259XT - Silicon Motion, MEMORY: SYMN09TC1B1AM6D (YMTC TLC ?))
F2-210. Detect fine.
f2-210
dhfh522
Post by dhfh522 »
I'm running a 1Tb Intel 670P. It seems to operate normally as cache for the storage pool, but I get no Smart statistics for it in the GUI console, so I have to check health and wear level from a ssh session.
Setup:
TOS 5.1.29
T9-423(16GB)
9 x 3TB HGST Ultrastar 7K4000
Setup:
TOS 6.0.650
T9-423(16GB)
1 x Intel 1Tb 670P Hyper-Cache
8 - members in TRaid array, 1 - Hot Spare
1 Storage pool with 2 Volumes
Backup
D5-300C
4x14TB ST14000NM0018 in TRaid array
1 Storage pool with 1 volume
enovella
Post by enovella »
Can anyone confirm if this M.2 SSD works well on the F4-223?
Crucial P3 1TB M.2 PCIe Gen3 NVMe SSD - Up to 3500MB/s - CT1000P3SSD8
https://www.amazon.es/Crucial-CT1000P3S ... 9hdGY&th=1
enovella
Post by enovella »
joergurmel wrote: 20 Dec 2022, 03:36 Habe zwei Crucial PCI 3.0 NVME M.2 SSD jeweils 1 TB verbaut. Gehen auch!
Und noch 8 GB Ram von Terramaster! Terramaster F4-423!
Crucial P2 or P3?
mandrael
Post by mandrael »
I bought the Transcend TS1TMTE220S 1TB because of the high TBW and because I have good experience with Transcend products.
SSD chips are on both sides.
I created a cache RAID 1, but inspite of that during sync the T6-423 began to beep. And this with thermal pads. Over 70 degree Celsius.
Can you recommend a cooling option? There is not much space. The idea would be to somehow thermal connect the SSD with the massive metal case. But I don't know what could accomplish that.
I'll remove the case and try to cool with a fan and/or a metal cooling option for both sides SSDs.
Is there already a solution for the SSD overheating issue with the T6-423?
Thanks, Michael
If an SSD is under a sustained high workload, it will generate enormous heat. It is recommended that you add a heatsink to your SSD.
something like this:https://www.amazon.com/Heatsink-Support ... 407&sr=8-9
mandrael
Post by mandrael »
the SSDs already overheated during sync.
Will there be enough place in the case for a SSD heatsink? There seems to be not enough place. Did you test the recommended heatsink?
Best, Michael
kwandart
Post by kwandart »
mandrael wrote: 20 Apr 2023, 22:57 Hi,
Best, Michael
Just wondering if you used the heat sink recommended (or something else) and how it worked out?
Return to “Compatibility”
