Problem with Fan-Connectors
donsenilo
Post by donsenilo »
Hi
I bought 2 Noctua NF-A8 PWM 4-Pin 80mm Fans:
but I can't use them because the connector does not fit to the socket of the NAS.
The original fans are Yeehon a8025l12s:
The connectors: Noctua 4pin PWM, Yeehon, a connector cable I bought
Can someone please explain what type of connector the Yeehon is ?
It's obviously not a standard PWM connector and it's to big for a 4pin fan-connector.
Help please !!!
Terramaster F4-210
Re: Problem with Fan-Connectors
What's the issue with the original fan?
It's suggested to use original fax in our TNAS.
You can contact Amazon TerraMaster and ask for a replacement of the fan.
Tricky
Post by Tricky »
I would suspect that he wanted to replace the fan because the std fan is not quiet and in an environment where it desired to be quiet hence the Noctua fan replacement as they have a reputation for being very quiet i have one fitted to an NVR because of this.
At the risk of voiding warranty you could just cur off the original and solder the wires to the Noctua....but dont Noctua fans come with converter leads? mine did.
donsenilo
Post by donsenilo »
Yes, the standard fans are very cheap and noisy.
The Noctua NF-A8 has no converter leads (I'm not sure what you mean by that). What fan do you use and what is a NVR ?
Terramaster F4-210
Tricky
Post by Tricky »
I fitted one of these https://noctua.at/en/nf-a4x20-flx to a network video recorder for CCTV it came with an impressive collection of adapter wires/plugs.
donsenilo
SOLVED: Problem with Fan-Connectors
Post by donsenilo »
I've done it !!!
If you are interested, here is my article: https://planetaustria.com/2020/09/29/te ... weiterung/
Terramaster F4-210
taybahau84
Post by taybahau84 »
Yeah,I just bought my f2-422 ,the fan not running, I don't know it run when device get hot or something, but anyway my fan right now not working, so can someone help me this please?
Tricky
Post by Tricky »
taybahau84 wrote: 04 Dec 2020, 01:59 Yeah,I just bought my f2-422 ,the fan not running, I don't know it run when device get hot or something, but anyway my fan right now not working, so can someone help me this please?
Have you been into settings then hardware and power and set the fan speed?
Enigma55
Post by Enigma55 »
I also keep getting error notifications on my new F5-422 NAS that my hard drives' temperature are too high. This repeatedly occurs whenever I do a chunk of file copying tot he NAS across my network. I also can't tell if the rear fans on the NAS are even working. They don't seem to be and I have tried every speed option in the Power settings on the NAS desktop console. No matter which of the four speeds I choose I can't tell any difference in the noise levels or fan exhaust output when I put my hand behind the NAS. Is there a way to check if these fans could be disconnected accidentally or malfunctioned?
You can easily check if the fan is working. At the meanwhile, you can check the fan speed on Control pannel > system information > hardware information.
