F4-210 RAm is full without any work
Permissions, domain/LDAP, power, security, notification and more.
Marchina
Re: F4-210 RAm is full without any work
Post by Marchina » 20 Jul 2020, 02:27
I have the same exact issue and also on the f4-210
Customer Service
Post by TMroy » 21 Jul 2020, 00:39
Your InitBoot need to be updated.
To contact our tech team or want a remote session, please email to support(at)terra-master.com
Customer Service
Post by TMSupport » 21 Jul 2020, 18:42
Please check the instructions from this link viewtopic.php?f=75&t=647
Tricky
Post by Tricky » 21 Jul 2020, 23:22
What happens if you run 8 or 10 gig od memory?
Customer Service
Post by TMroy » 23 Jul 2020, 23:27
@Tricky What did you mean?
Tricky
Post by Tricky » 24 Jul 2020, 00:54
Those updates where for the ...
Applicable model: F2-210 / F4-210
Download link:
For 1GB Memory model:
http://dl.terra-master.com/cn/firmware.img
For 2GB Memory model:
http://dl.terra-master.com/en/firmware.img
I was asking what happens if you have installed extra memory...however i am not sure that those models can accommodate extra RAM?
Customer Service
Post by TMSupport » 24 Jul 2020, 14:07
F2-210/F4-210 do not support adding extra RAM.
scoobyfizz
Post by scoobyfizz » 24 Jul 2020, 14:23
Even after the init boot fix I thing there is a memory leak. A reboot shows 40% ish... then over the course of a day or so creep back up to 90%.. I did have plex server running as it was 'blamed' but I do not now and it is still the same....
Jonas Pi
Post by Jonas Pi » 24 Jul 2020, 17:18
For me the firmware upgrade did apply well,
I've done it with putty, worked fine so far.
The RAM is at round about 12-15% after reboot.
I'll keep an eye on that,
if anything occurs i'll let you know.
Jonas
F4-210
Jonas Pi
Post by Jonas Pi » 25 Jul 2020, 05:39
...in addition to my last post:
The RAM won't unload after copying data from the internal NAS drives to an external drive (USB) via (Windows-) Computer.
It remains at round about 95% even though i'm not doing anything with my NAS at the moment.
After reboot it remains low (10-20%) but after accessing files or copying them from the nas to another drive or pc the RAM remains full.
sincerly,
Jonas
F4-210
