F4-220 Replacement Fans
- rgblack316
Both of the fans in my F4-220 are failing and need to be replaced. They use a different connector than a standard computer fan. Where can some replacements for these be found? Is the pin-out the same as a standard PC fan so one of the proprietary connectors can be soldered onto a standard fan to be used?
Re: F4-220 Replacement Fans
Our fan specification is 80×80×25, pwm. You can purchase fans with the same specifications yourself.rgblack316 wrote: ↑24 Dec 2022, 21:48 Both of the fans in my F4-220 are failing and need to be replaced. They use a different connector than a standard computer fan. Where can some replacements for these be found? Is the pin-out the same as a standard PC fan so one of the proprietary connectors can be soldered onto a standard fan to be used?
- rgblack316
I did purchase fans that meet that specification. The header on the system board is NOT a standard 4 PIN PWM connector.
