F4-423 DDR4 memory modules upgrade
Re: F4-423 DDR4 memory modules upgrade
The module work perfectly with TOS5 on F4-423, without any adaptation of the BIOS or other file.
F4-423. Replaced stock module with 2 kingston bars. Works perfectly. TOS 5.1.13 Beta
Handle 0x0047, DMI type 17, 100 bytes
Memory Device
Array Handle: 0x003A
Error Information Handle: Not Provided
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Controller0-ChannelA
Bank Locator: BANK 0
Type: DDR4
Type Detail: Synchronous
Speed: 3200 MT/s
Manufacturer: Kingston
Serial Number: C0B42928
Asset Tag: 9876543210
Part Number: KF3200C20S4/8G
Rank: 1
Configured Clock Speed: 2933 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Handle 0x0048, DMI type 17, 100 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Controller0-ChannelB
Bank Locator: BANK 1
Type: DDR4
Speed: 3200 MT/s
Serial Number: BFB435DB
Rank: 1
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Type: DDR4
Speed: 3200 MT/s
Rank: 1
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Type: DDR4
Speed: 3200 MT/s
Rank: 1
On version TOS 5.1.13 Beta, as I understand it, the check is removed, so any memory works.
I changed modules when i bought device. It was TOS 4... Changed modules, used 4 TOS, then 5.0, now 5.1. Never had problems with memory restriction.
- epsilonion
I am considering the desktop 6 bay NAS, have they officially removed the ram check so you can use any ram manufacturer or is it just for the BETA?
I will not be buying if its locking out other manufacturers and over pricing there own RAM..
It should clearly be marked on there advertisements and product page only officially allowed ram is terramaster ram..
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 156
Model name: Intel(R) Celeron(R) N5095 @ 2.00GHz
Stepping: 0
CPU MHz: 2000.000
CPU max MHz: 2900.0000
CPU min MHz: 800.0000
BogoMIPS: 3993.60
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 1536K
L3 cache: 4096K
NUMA node0 CPU(s): 0-3
{L_BUTTON_AT}outkastm
