Il give UP.
Tried with multiple connections nothing is working.
If support terramaster could provide pinouts or just pins to connect with right resistor. That would be great.
But for now. I think I Will recycle my old pc to convert it to freenas or something similar.
Just wondering how to recover data raid6.
F4-220 - Start problem
Re: F4-220 - Start problem
isnt't it just a linux software raid with ext4 for the f4-220?
you can try to reassemble the raid with mdadm using any linux, just hoping that terramaster used the standard chunk sizes that mdadm suggets.
