tnas f4-210 not loadin
erezhe
Post by erezhe »
My TNas is not loading. tried unpluging removing all HDD's starting and putting them back.
now It is going to databack\checkraid and get 404 (see attachment).
I have the disks set to raid 5 or 10 I'm not sure( i think raid 5).
what should i do? please advice?
Re: tnas f4-210 not loadin
Hi! It may be caused by the abnormal file system, it is recommended that you try to repair the file system following the link:
viewtopic.php?f=75&t=2575
erezhe
Post by erezhe »
failed to connect
Putty says
PuTTYNG Fatal Error
Network error: Network error: Connection refused
OK
also telnet failed
C:\Users\erez_h>telnet 192.168.1.80 9222
Connecting To 192.168.1.80...Could not open connection to the host, on port 9222: Connect failed
Hardfecx
Post by Hardfecx »
you don't even get an webinterface?
have you pinged your ip adress?
erezhe
Post by erezhe »
I get only the loading bvar
I get ping.
C:\Users\erez_h>ping 192.168.1.80
Pinging 192.168.1.80 with 32 bytes of data:
Reply from 192.168.1.80: bytes=32 time=4ms TTL=64
Reply from 192.168.1.80: bytes=32 time=9ms TTL=64
Ping statistics for 192.168.1.80:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 4ms, Maximum = 9ms, Average = 5ms
Hi! It seems some files of system are lost or damaged. Please try to reinstall TOS to fix it.
After reinstallation, it is recommended to check and repair the file system.
viewtopic.php?f=75&t=423
erezhe
Post by erezhe »
Still no way to log on to ssh.
Hi! Have you reinstalled the system? If it has been reinstalled, please report the current operating status of your system.
erezhe
Post by erezhe »
reinstalled the system.
and again same loading bar and no login access.
