I have a 8TB HDD, which has stuff on it, and it needs permission, its file access via network is public 2, but public 1 which is a 4TB drive, gets access and I can drag etc into it, however Public 2, requires access through explorer file, but in web based app it works fine. Is there a setting I am missing?
I basically was just messing around with the settings of the shared file, I deleted Public2, which had all the tv data, still shows 3.2 TB used, so.. plex isn't completely lost, but I recreated Public, and it doesn't show, how do I recover this data? lol... I don't want to re download 3.2 TB of data...
And after messing around with the settings they now work in the shared files but I still would like to know how to recover the deleted shared file Public2 to restore it, but if its restored does this mean I cant access the file via networking file explorer?
F4-210 HDD2 needs permissions
- silentspanky
Re: F4-210 HDD2 needs permissions
I went into advanced and am trying to restore the volume 2, but.... I hope it works unless there is a cmd line or file extension for such information to restore
- silentspanky
info off of disk 2
Good,"No abnormalities were detected on this hard drive."
"Hard Drive","Seagate IronWolf"
Model,ST8000VN004-2M2101
"Serial Number",WKD34RAY
Capacity,"8,001,563,222,016 bytes [8.00 TB]"
Firmware,SC60
"ATA Version","ACS-4 (minor revision not indicated)"
"ATA Standard","SATA 3.3, 6.0 Gb/s"
ID,Attribute,Value,Worst,Threshold,"Raw data",Status
0,Raw_Read_Error_Rate,083,064,044,205520045,ok
1,Spin_Up_Time,087,082,000,0,ok
2,Start_Stop_Count,100,100,020,40,ok
3,Reallocated_Sector_Ct,100,100,010,0,ok
4,Seek_Error_Rate,076,060,045,37152312,ok
5,Power_On_Hours,094,094,000,5978,ok
6,Spin_Retry_Count,100,100,097,0,ok
7,Power_Cycle_Count,100,100,020,36,ok
8,Reported_Uncorrect,100,100,000,0,ok
9,Command_Timeout,100,100,000,0,ok
10,Airflow_Temperature_Cel,058,052,040,42,ok
11,Power-Off_Retract_Count,100,100,000,28,ok
12,Load_Cycle_Count,100,100,000,723,ok
13,Temperature_Celsius,042,048,000,42,ok
14,Hardware_ECC_Recovered,083,064,000,205520045,ok
15,Current_Pending_Sector,100,100,000,0,ok
16,Offline_Uncorrectable,100,100,000,0,ok
17,UDMA_CRC_Error_Count,200,200,000,0,ok
18,Head_Flying_Hours,100,253,000,5836,ok
19,Total_LBAs_Written,100,253,000,8403679179,ok
20,Total_LBAs_Read,100,253,000,29828125340,ok
Firmware,SC60
- silentspanky
Pulled the drive, doing a data recovery with mini part tool, with a 3.5 usb external, doing a data recovery for it. I hope it works.... lol
- silentspanky
Had to dig out the old IDE/SATA Docking to place the nas drive into, and use mini tool recovery, 3.2 TB I transferred from one drive to the other, I then went playing around with the shared folder settings, accidently deleted, did the advanced portion and boom. Gone on HDD2, HDD1 I just deleted them, I am hoping it restores it. Will take some time, which is a huge understatement but if it restores all that data. I will be ok.
