PHP SSL certificate fails
arqweryon
Post by arqweryon »
I have a F5-422 with TOS 5.0.155-00202 and I installed the Web Server app to try and host pixelfed. Pixelfed requires composer app (https://getcomposer.org/download/) and following instructions, when I try to download anything, it fails due to openssl error:
The "https://getcomposer.org/versions" file could not be downloaded: SSL operation failed with code 1. OpenSSL Error messages:
error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
Failed to enable crypto
failed to open stream: operation failed
Retrying...
Retrying...
The download failed repeatedly, aborting.
Is there a certificate I should install to be able to access https via TOS?
Thanks,
arqweryon
Re: PHP SSL certificate fails
Post by arqweryon »
In the end I found the following post: viewtopic.php?f=37&t=2529&p=19150&hilit ... tes#p19150
Which inspired me that maybe it was just a php.ini problem (https://stackoverflow.com/questions/725 ... ify-failed).
So I edited /etc/php.ini
and added:
[curl]
curl.cainfo = /etc/ssl/certs/ca-certificates.crt
[openssl]
openssl.cafile = /etc/ssl/certs/ca-certificates.crt
And problem was solved. So it just needed pointing to ca-certificates.
Return to “Security”
