Can't create volume
Jac de Lad
Can't create volume
Post by Jac de Lad »
I have a F2-210 with one drive as single disc. So far so good, I added a second drive, it's recognized and I wanted to create a second volume. Formatting starts, but afterwards o only have the second pool, but no volume. And I have no option to create a volume. Am I doing something wrong?
Re: Can't create volume
Hi! You can try to recreate the second storage pool and then create the second volume.
Jac de Lad
I alread did. The pool is then present, but I can't create a volume (the option is not available).
What if you try reboot it?
Maybe this can fix an unknown error so that the volume can be created.
You can also send an email to the technical support mailbox, so that we can better analyze the problem.
Jac de Lad
I rebooted twice. All the general troubleshooting stuff. Removing the drive and plugging it in again. It's recognized, but I can't create a volume, just a pool.
I'll write an email to the tech support. If TOS 5 isn't too far away I can also wait if it works there.
You can try to remove your second drive, delete all partitions and format it on your computer, then try again.
Jac de Lad
I'll try this on weekend.
Jac de Lad
Didn't work...meh.
