Initboot update required for high memory usage
Instruction
As for the high memory usage issue, Initboot update is required. Please follow the instructions below to release the memory.
Applicable model: F2-210 / F4-210
Download link:
For 1GB Memory model:
http://dl.terra-master.com/cn/firmware.img
For 2GB Memory model:
http://dl.terra-master.com/en/firmware.img
Instructions:
1. please download the suitable file;
2. SSH login to access your TNAS as root, the password is the same as admin’s password;
3. enter the command ter_wget and the correct download link such as:
ter_wget http://dl.terra-master.com/cn/firmware.img
4. when the download is completed please execute
cp firmware.img / tmp /
5. input cmd up.sh and press enter;
6. wait for about 5-10 minutes until it displays [root@TNAS-00129F ~]#
7. reboot TNAS.
Notes:
1. It will take 5 – 10 minutes , do not power it off until it completes.
2. The transcoding feature of multimedia server would be affected and it could not be used after memory release.
