How to reinstall TOS for your TNAS?
rightLANE
Re: How to re-install your TOS?
Post by rightLANE »
rightLANE wrote:
> So if I have 4.2.13 installed, am I allowed to just install 4.2.09 over it?
BTW, I do want to keep TOS updated, just with everything I've read, I'm very reluctant to. I use my NAS primarily for Plex so it's hard to justify upgrading if I'm going to loose this ability.
SquarePeg
Wales
Post by SquarePeg »
sngillis wrote:
> I've done this twice now on my F4-210 and at no point in this process am I
> presented with an option to install a new OS. It merely loads the 4.1.32
> version of TOS. When I click 'login', I go to the TOS desktop.
> How do I get the new OS loaded?
> PS I tried to simply update to 4.2.07 and it keeps hanging at the unzipping
> stage (it says it needs two minutes, but 2 hours later, it still needs two
> minutes).
Same here
TMS
Post by TMS »
{L_BUTTON_AT}rightLANE
If you have installed the 4.2.13 TOS system, you cannot install 4.2.09. Only one system can be run.
TMS
Post by TMS »
{L_BUTTON_AT}SquarePeg
Refresh the browser (or change the Google browser to try to update), check whether the update package is ARM models.
rightLANE
Post by rightLANE »
So if I want to downgrade, I'd have to follow method 2, then upgrade to the version I want to be on?
donsenilo
Post by donsenilo »
I have done option 1, the NAS is running but I can't access the login-page. The TNAS PC App found the NAS correctly.
Immediately HELP please !!!
donsenilo
Post by donsenilo »
Chrome writes "ERR_CONNECTION_REFUSED"
What's your TNAS model number?
Please try with option 2.
AlbertoGon
Post by AlbertoGon »
I have to change the hard disk in terramaster F5-221 where TOS is installed because I have run out of space, I have followed the instructions and when I go to point 7 and I give it to update and restore it restarts but it does not start, it only appears on the screen cannot touch /tmp/databack/complete : no such file or directory.
Can you please help me
Thank you
TMroy wrote:
> [b]Instruction[/b]
> Applicable model: All TNAS models
> If you wish to re-install the TOS system, or your TNAS encounters a failure and needs
> to reinstall TOS, please refer to the following guidelines:
> [b]Method 1: If your TOS system is still working[/b]
> 1. Log in to TOS and go to [b]TOS Desktop> Control Panel> General Settings>
> Update and Restore> Backup and Restore[/b];
> 2. Tick "Backup system configuration" to back up your system configuration;
> 3. Go to [b]TOS Desktop> Control Panel> General Settings> Update and
> Restore> Restore to Factory Default[/b];
> 4. Tick "Restore to factory default", and then click "Apply";
> your system will be erased, but the data on the hard drives will not be deleted;
> 5. Refresh the browser page, and follow guide on the page to install a new TOS;
> 6. If the page refresh fails, please use TNAS PC to search for your TNAS device; Then
> select the device and click "Login"; Follow the web page to install the new
> TOS;
> 7. After the system installation is complete, log in to TOS and go to [b]TOS
> desktop> Control Panel> General Settings> Update and Restore> Backup and
> Restore[/b] to restore your backed up system configuration.
> [b]Method 2: If your TOS system encounters a malfunction and cannot work properly[/b]
> 1. Turn off your TNAS device;
> 2. Remove all hard drives;
> 3. Turn on your TNAS;
> 4. Wait about two minutes, after the network light is on, insert your hard drives;
> 5. Use TNAS PC to search for your TNAS device;
> 6. Select the device and click "Login"; Follow the instructions on the web
> page to install the new TOS system.
> Note: Reinstalling the system normally will not delete the data on your hard drives,
> BUT to prevent accidents,it is recommanded to backup your data before reinstalling.
> If you have any questions when operating the above steps, please contact us in time.
Madvic
Post by Madvic »
I followed the process: started without any HD, once connected to the web intrerface I inserted the disk and got the prompt to "Initialize"
Everything is working, but I can't see my old partitions with data. The System reports the space as used but I can't access it.
How can I recover the partitions? I can't lose that data, it's important.
Thanks in advance
