Instruction
When you initialize your newly purchased TNAS device on our linux computer, follow the instruction below:
1. Download and install TNAS PC (for Linux) program to your Linux system, https://dl.terra-master.com/cn/TNAS PC_For_Linux
2. Locate the directory for TNAS PC, under /mnt for example.
3. SSH login with Terminal to execute the following command: sudo chmod –R 777 /mnt/TNAS PC _For_Linux
4. sudo /mnt/ TNAS PC _For_Linux
5. The TNAS IP address will be shown.
6. Enter the listed TNAS IP address into the browser's address bar to access your TNAS.
How to find TNAS device on a Linux system?
