How to access your TNAS when the obtained IP address is started as 169.XXX.XXX.XX?
Frequently asked questions, operating instructions, troubleshootings
Customer Service
Post by TMSupport » 18 May 2021, 14:19
Applicable models: all TNAS models.
Troubleshooting
The obtained IP address of TNAS would be 169.168.xxx.xx when there is no DHCP server in your network. Your TNAS could be detected but could not be accessed when the TNAS IP address is 169.xxx.xxx.xx.
Instructions:
1. Enable the DHCP feature on your Router and then run TNAS PC to search again. It will ask you to change the IP address when clicking Login, the default password for changing IP address is admin for X86 models and Admin123 for ARM models.
2. Connect your TNAS to your computer directly using the ethernet cable and then:
2.1 Right click the Network icon at the right corner on your PC's desktop, and check Open Network and Sharing Center;
2.2 Click change adapter settings;
2.3 Right click Ethernet and check Properties, check Internet Protocol Version4 and click Properties;
2.4 Choose Use the following IP address and change the IP address to 198.168.xxx.xxx.
2.5 Run TNAS PC program again, and click Login or Change IP, enter the correct password to change the IP address of your TNAS.
2.6 Click Login to access TOS web page, and go to TOS Control panel- Network services- Network Interface - click Edit to set a static IP address for your TNAS by checking "Use the manual configuration noted below.
