Attaching Boot ISO
ChrisSproston
Attaching Boot ISO
Post by ChrisSproston »
Apologies first as I'm a newbie!
I'm trying to create a Windows 10 VM. All good but when I try and choose a virtual optical disk file I can only see the folders withing the VirtualBox App? I can't see the Volume on the NAS where my ISO file for windows 10 is?
What am I doing wrong??
Thanks.
Re: Attaching Boot ISO
It's under directory /mnt/md0/ .
tasete30
Post by tasete30 »
I have a a virtual box folder and I'd like to use it instead a ISO file.
Which folder I should use to load VM in NAS to use in Virtual Box? VB always reject to use internal folders....
Also I don't know how to see internal folders in disk manager.
Could you help me?
BR.
You can put the ISO file under Public, and the directory would be /mnt/md0/public . You can select this directory when choose the image file.
The internal folders of VM could not be checked at the moment.
Return to “Virtual Machines”
