VirtualBox USB port
sports_wook
VirtualBox USB port
Post by sports_wook »
I'm trying to use my virtual machine to access a USB device that is plugged into my TNAS device. I've setup the USB settings for the machine (enabled, controller, filter), but the device does not register in the machine OS.
TOS 4.1.21 on F2-220, running latest Debian Buster in VM through Virtual Box. Any suggestions or help would be greatly appreciated.
sports_wook
Re: VirtualBox USB port
I'm also unable to install any Guest Additions. When I attempt this selction from the menu, I receive one of the following errors (sometimes one, sometimes both):
"undefined - The image file '/usr/local/share/virtualbox/VBoxGuestAdditions.iso' is inaccessible and is being ignored. Please select a different image file for the virtual DVD drive."
"Failed to update Guest Additions. The Guest Additions installation image will be mounted to provide a manual installation."
Thank you for your report! We will add it into our beta issus list.
sports_wook
Thanks but any suggestions on how to fix it or will that require a software update/patch?
We are still collecting issues reported from our users, I can't tell you know.
And by the way, your model F2-220 hardware is not powerful enough to support virtual machine. To support virtual machine, your hardware need to at least x.86 quad core and 4GB ram.
sports_wook
I upgraded to RAM to 4gb so I meet the requirement. Not sure about the processor, but I doubt I have that. Regardless, it's working flawlessly for my F2-220.
Was VirtualBox pulled from the Applications store? Or was it pulled for only F2-220? I don't see it in the Applications anymore, but it's still installed/working properly and shows on my desktop.
To ensure better user experience, the coming new release will limit the app just available for some dadicated models.
sports_wook
But it won't be revoked from my system, correct? I installed it while it was in the Application store and still have it installed. Guess I can just never remove it VirtualBox from my system if I want to continue using it, and it will never be updated for my system?
chourmovs
Post by chourmovs »
TMroy wrote: 06 May 2020, 22:40 To ensure better user experience, the coming new release will limit the app just available for some dadicated models.
:shock:
Please, please
F2 220 is only 2gig ram and i run several headless distro with very good result (alpine and volumio)
Don't remove it from the eligible device, volumio is the only dlna sever that work 100% for me
Thank you for your consideration
Vincent
TNas F2-220
Still do not know which models will be supported in the final release yet. But we will forward your demand to the team. Don't worry.
Return to “Virtual Machines”
