VirtualBox Virtual Machine is online now in TOS APP center
Tricky
Post by Tricky » 30 Apr 2020, 06:17
Just installed this and tried installing Ubuntu and expected it to be like installing on a PC but once Ubuntu 32bit was selected there was no option to select a downloaded iso file ...not overly failure with this so could be me so can you tell me how to install Ubuntu into virtual-box on the TNAS?
Customer Service
Re: VirtualBox Virtual Machine is online now in TOS APP center
Post by TMSupport » 07 May 2020, 15:19
Hi, please upload the iso file to your TNAS first, and the click start, and choose the directory. If the iso file is saved under public, then the directory should be /mnt/md0/pubilc .
Tricky
Post by Tricky » 07 May 2020, 16:32
Thanks for that...thought i had tried that but will give it another go.
Tricky
Post by Tricky » 07 May 2020, 17:02
Just tried again and the Ubuntu file does not show up, should it be a a particular format of container file for it to show?
Customer Service
Post by TMSupport » 08 May 2020, 14:57
There is no specific demand on the format. Could you take some screenshots and post here?
Tricky
Post by Tricky » 08 May 2020, 17:08
Finally found the image under a different sub folder link but still cant seem to get it to install Ubuntu from it just keep getting error.
Customer Service
Post by TMSupport » 08 May 2020, 17:39
Could you post a screenshot here?
