This happened to me for the second time this week. After about two days I can't login to phpvirtualbox, it gives a bad gateway error after login.
When I restart virtualbox (/etc/init.d/vbox restart) the TNAS becomes unresponsive and I need to force poweroff on it (so I need remote hands and/or go to the basement). I've already opened a ticket through TOS with error reports attached, but it's frustrated and am curious if more people experiencing probles. I've only have 1 small VM running only an openssh server for testing (wanted to run a webserver on it... when it's stable).
Virtualbox crashes TNAS
Re: Virtualbox crashes TNAS
Just upgraded to 4.2.18, now virtualbox app icon open's a blank page and immediately the TNAS is inresponsive and needs a cold reboot.
Going to order a wifi power plug so I can do this remotely...
Hi! It is not clear what caused it. You can try to uninstall the virtualbox app, and then delete all configuration files of the virtualbox app.
