VM's Missing After Update
WaggersR
Post by WaggersR »
I've just updated VirtualBox to 6.1.4_V1.02 on my F2-221 and my VM's have disappeared.
Does anyone know where the VM's files are stored so I can import them back into VirtualBox?
TMS
Re: VM's Missing After Update
Post by TMS »
As shown in the attachment:
WaggersR
Post by WaggersR »
Sadly, I can't see that in my tree.
Luckily, I have a snapshot so I can rebuild and restore my VM. However, It's strange that everything has gone after the update. Is this a bug do you think?
TMS
Post by TMS »
Did you choose the right directory?
home>vbox>home>VirtualBox VMS
WaggersR
Post by WaggersR »
Ah, found them.
mnt>md0>user>vbox>home>VirtualBox VMs>Home Assistant
TMS
Post by TMS »
Yes,select Home Assistant.vbox and click OK.
Return to “Virtual Machines”
