Can´t run any VMs
octekin
Can´t run any VMs
Post by octekin »
I can´t run any VMs in VirtualBox.
I get everytime the same ErrorMessage.
Please help. Thanks in advance
Exception Object
    [message:protected] => The virtual machine 'hass.io' has terminated unexpectedly during startup with exit code 1 (0x1)
    [string:Exception:private] =>
    [code:protected] => 0
    [file:protected] => /mnt/md0/application/share/virtualbox/vbox/endpoints/lib/vboxconnector.php
    [line:protected] => 2443
    [trace:Exception:private] => Array
            [0] => Array
                    [file] => /mnt/md0/application/share/virtualbox/vbox/endpoints/lib/vboxconnector.php
                    [line] => 951
                    [function] => remote_progressGet
                    [class] => vboxconnector
                    [type] => ->
                    [args] => Array
                            [0] => Array
                                    [progress] => 0a507831c7ac2abf-0000000000000004
            [1] => Array
                    [file] => /mnt/md0/application/share/virtualbox/vbox/endpoints/api.php
                    [line] => 316
                    [function] => __call
                    [type] => ->
                    [args] => Array
                            [0] => progressGet
                            [1] => Array
                                    [0] => Array
                                    [1] => Array
                                            [0] => Array
                                                    [data] => Array
                                                            [responseData] => Array
        [info] => Array
        [completed] => 1
        [canceled] =>
        [description] => Starting VM
        [operationDescription] => Creating process for virtual machine "hass.io" (headless)
        [timeRemaining] => Array
        [timeElapsed] => Array
        [days] => 18762
        [hours] => 19
        [minutes] => 53
        [seconds] => 30
        [percent] => 0
                                                            [success] => 1
                                                            [key] => 53474945cfd7ac0bf8114767c209c2a6
                                                    [errors] => Array
                                                    [persist] => Array
                                                    [messages] => Array
    [previous:Exception:private] =>
chemanue
Re: Can´t run any VMs
Post by chemanue »
I have reinstalled the operating system and I can't run any VMs.
I have tried to create a new test virtual machine and have not been able to run it either.
Exception Object
    [message:protected] => The virtual machine 'prueba1' has terminated unexpectedly during startup with exit code 1 (0x1)
            [0] => Array
                    [line] => 951
                    [type] => ->
                    [args] => Array
                            [0] => Array
                                    [progress] => ef2a39f78322c6bf-0000000000000004
            [1] => Array
                    [line] => 316
                    [type] => ->
                    [args] => Array
                            [0] => progressGet
                            [1] => Array
                                    [0] => Array
                                    [1] => Array
                                            [0] => Array
                                                    [data] => Array
        [info] => Array
        [completed] => 1
        [canceled] =>
        [operationDescription] => Creating process for virtual machine "prueba1" (headless)
        [days] => 18764
        [hours] => 9
        [minutes] => 43
        [seconds] => 47
        [percent] => 0
                                                            [success] => 1
                                                    [errors] => Array
                                                    [persist] => Array
                                                    [messages] => Array
TMS
Post by TMS »
VirtualBox is being repaired and tested, please wait for app update.
