Why is my rclone process using 180% CPU?
Rockybeach
Post by Rockybeach »
See attached screen shot....
screen shot
screen shot
TMwuu
Re: Why is my rclone process using 180% CPU?
Post by TMwuu »
Rockybeach wrote: 12 Nov 2022, 01:48 See attached screen shot.... Capture.JPG
You should be in the backup, which is normal. After the backup is completed, it will return to normal.
swmiller
Post by swmiller »
I have the same problem. My NAS Iis always high CPU due to rclone process. I only have onedrive sync (fully sync) and Plex. There is no backup. It happens now for 4 days.
What should I do? Help
Mizuma
Post by Mizuma »
I updated to TOS 5 as I hoped the new Cloud Sync would be better, but it seems even worse right off the bat.
- Before even setting up any connection or task, the CloudSync process has a 3% CPU usage idle. (!!!!)
- It writes logs to disk every SECOND, keeping it from hybernating. I noticed that both for the "overview.info" log (seemingly for the perf graph) that can't be disabled, and in its config/gin_http.log directory
Can this please be fixed as well ?
{L_BUTTON_AT}swmiller
Which TOS version is installed? Which application did you use?
Mizuma wrote: 27 Dec 2022, 05:41 - Before even setting up any connection or task, the CloudSync process has a 3% CPU usage idle. (!!!!)
Q1 is being optimized, and Q2 will be verified soon.
