I'm the owner of a NAS F5-221 and I'm facing a problem of CPU consuption with 2 process
minidlnad (96,5%) CPU1
aiface (88,73%) CPU2
Could you tell me what process are they?
Perhaps are multimedia programs scanning, but I'm not sure and I'd like to know it to stop it.
BR.
excesive consuption in 2x process
Re: excesive consuption in 2x process
minidlnad is the process of media index, you can disable it in control panel - media index.
aiface is the process of face recognition, you can disable it in TerraPhotos- settings, it is recommended that you enable it when the device is idle.
Note: Disabling media index will affect the use of TerraPhotos.
