F2-422System will not boot with 2 Drives installed.
JoeHolden
Post by JoeHolden »
Good Afternoon,
My F2-422 Device has powered itself off overnight.
When it has come to applying power again, the device LED's illuminate for around 4-5 seconds, the fan and drives spin up, and then the device kills power again.
When the device is started with just a single drive installed, it powers on fine and I can access the TOS. This is the same with both drives, in each bay, so I'm 99% sure its not a drive issue - both drives also pass S.M.A.R.T tests.
Any advice on this issue would be appreciated! Thank you.
Joe
Return to “System Resources”
