TNAS F5-221 CPU at 100%
frostyxyz
Post by frostyxyz »
Hi I've just noticed my system is running constantly at 100% and it's mainly a process called systemd-firewal that's causing it. Do you know what this is and if if I can somehow disable it?
Many thanks.
picture of the top three processes, rest were at 0% at the time.
Re: TNAS F5-221 CPU at 100%
Your machine has infected with the mining virus, please follow the steps below to remove the virus.
1.Log in to the SSH terminal
2.Switch to the bin directory.
cd /bin/
3.Delete virus execution files.
rm -rf ./systemd-firewal
4.Find the process id of systemd-firewal.
ps -ef|grep systemd-firewal
5.Kill the process.(ID is the process id)
kill -9 ID
6.Restart the TNAS device.
Hardfecx
Post by Hardfecx »
and how to delete the process completely?
TMRyan
Post by TMRyan »
After deleting the systemd-firewal file and killing the process, the miner is removed.
To clean it up completely you can use the following command to delete the line of code that has firewall in it.
vi /etc/crontabs/root
In other cases, you can refer to the following: viewtopic.php?f=71&t=2292&p=12383&hilit=pty10#p12383
frostyxyz
Post by frostyxyz »
Thank you for your replies. Ok I managed to do all that above. And it kills it but seconds later a new process with a same name but with a different process id takes it's place.
i.e. I've done the following steps:
Login to SSH via putty
cd /
sudo -i
[password]
cd /bin/
kill -9 [the first number shown in the ps]
... then manually deleted the line with the firewal
Any ideas?
frostyxyz
Post by frostyxyz »
I may have now resolved the issue. After doing the above, I did some of the steps in suggested by TMRyan here:
I then restarted the TNAS and so far, the process hasn't returned. I'll be sure to come back here if it comes back though. :)
Thank you all.
Return to “System Resources”
