Problem install pip3
MaitreKuc
Post by MaitreKuc »
Hello, I'm trying to install pip3, but it gives me an error.
I uploaded the file to https://bootstrap.pypa.io/get-pip.py, then ran the "python3 get-pip.py" command.
Python3 and pip are well installed.
How to install pip3?
Traceback (most recent call last):
  File "get-pip.py", line 23682, in <module>
    main()
  File "get-pip.py", line 198, in main
    bootstrap(tmpdir=tmpdir)
  File "get-pip.py", line 82, in bootstrap
    from pip._internal.cli.main import main as pip_entry_point
zipimport.ZipImportError: can't decompress data; zlib not available
NAS : F2-220
Re: Problem install pip3
Please advise your TNAS model number in return.
Please be noted that ARM models including F2-210/F4-210 do not have pip app at the moment.
MaitreKuc
Post by MaitreKuc »
I have an F2-220.
I had already managed to install pip3, but I reset my NAS and since then I have not been able to.
NAS : F2-220
Since we can't replicate the issue here about pip, please advise whether it’s ok to let our engineer has a remote session to check it. You can send an email to support(at)terra-master.com to confirm it.
ajs16
Post by ajs16 »
Please fix this problem. Pip is only working with python 2.7 and not 3.6. Python 2.7 is useless!
MaitreKuc
Post by MaitreKuc »
Support took remote control of my NAS, I sent an email yesterday to get news on this issue.
I will give you some news.
NAS : F2-220
ajs16
Post by ajs16 »
Thanks, I appreciate it!
MaitreKuc
Post by MaitreKuc »
Here is the answer:
Hello ,
The technician is confirming your required feature now, and will get back to your when there is a result.
Regards
NAS : F2-220
MaitreKuc
Post by MaitreKuc »
I made a tutorial to install Entware.
viewtopic.php?f=37&t=829
To install python3 :
opkg install python3
and pip3:
opkg install python3-pip
NAS : F2-220
Return to “Others”
