Mantis BT
dfarrell
Mantis BT
Post by dfarrell »
I have F2-210 with 2TB. Installed MariaDB, Svn, Git and lastly Mantis BT. Cannot seem to get in Mantis to set it up.
"Database connection failed. Error received from database was #2002: No such file or directory." I see the tables using phpMyAdmin.
Should I dump the app and just install mantis on its own?
Re: Mantis BT
Hi, I will check with the engineer here and will get back to you later.
Re: Mantis BT
Could you enter MySQL at Maria DB?
