Using Pip in ssh
Pombo90
Using Pip in ssh
Post by Pombo90 »
I installed pip through the application manager, but I cant find the command nor using it with python, I attached a image with the python versions I have installed.
Re: Using Pip in ssh
Hi, the pip application will be updated later to fix it. Will keep you informed when the new release is available.
Hi, the new version is available now. You can update the pip now.
Return to “Others”
