Deduplication Manager GUI needs more work
joejoeyou
Post by joejoeyou »
When the "deduplication" button is pressed at the bottom right, the popup panel's size is fixed. I cannot widen the popup window and it becomes impossible to inspect the complete address of the duplicated files. Please make the popup panel size adjustable in the next version.
Re: Deduplication Manager GUI needs more work
Thanks for your report, we will check it.
Return to “Others”
