Amazon S3 Sync
Discussion about CloudSync.
buzzkc
Amazon S3 Sync
Post by buzzkc »
I'm attempting to setup the S3 sync to a newly created bucket. I enter the Access and Secret keys, and can see the list of available buckets. I choose the bucket I wish to use and click confirm, but I'm getting a "Operation failed!" message.
I've tested the connection and bucket in other software and it works fine. Are there any specific permissions required by the application for it to connect and work?
Re: Amazon S3 Sync
Hi, did you input and connect using "admin" account?
buzzkc
Re: Amazon S3 Sync
Post by buzzkc »
Yes, I was using the administrative account.
buzzkc
Re: Amazon S3 Sync
Post by buzzkc »
I've also tried on both Chrome and IE with all plugins disabled, I get the same results.
buzzkc
Re: Amazon S3 Sync
Post by buzzkc »
@TMSupport Any suggestions?
Re: Amazon S3 Sync
Hi buzzkc,
We are not sure what caused the problem. We need to consult with engineers further. Since we are currently on holiday, we expect to come back to you on Wednesday.
coolshop_ab
Re: Amazon S3 Sync
Post by coolshop_ab »
Hello, just for reference, we have the same exact problem.
Thanks,
Alberto
Re: Amazon S3 Sync
Hi, could you please contact us support(a)terra-master.com, we will ask our engineer to have a remote session to check this issue.
