I upgraded to TOS 5, now on 5.0.128 version.
The Apps Center does not show any application (opr it randomly shows some of the installed ones).
Sending an applicaiton to the desktop only works randomly.
Applications Center Not Working
Re: Applications Center Not Working
If it cannot be displayed, you can try to click the refresh button of the browser. For applications without desktop icons, you can switch the language to English first. We will solve the problem that the application icons cannot be displayed in some languages as soon as possible.
- Charlie_Croker
I had this issue, drove me mad, try this:
1. Make sure your permissions are set correctly in Control Panel/Application
2. Switch Media index off (make sure it doesn't restart).
You should now be able to see the apps now (inshallah!) Good luck
I’m getting the same issue. It’s been over 24 hours of this now and I can’t even update apps?
I’ve managed to figure it out.. I have 2 IP addresses in my network interface tab. (One for an internet connection, another directly to my PC)
I could see in the general tab (in network settings) that the wrong interface was my main IP rather than the one I had setup for the internet connection.
If you go into the interface tab and then top right (Service Sequence) click the correct IP address and then Apply. This just fixed the issue for me and the correct IP/interface is now showing in the network general tab
Well, with TOS 5.0.130-00167 the situation is even worse.
Now the Applications Center is just empty
The CloudSync application has lost all of its connections, nothing is left, no tasks .,...
The software quality is worse with every release !!
{L_BUTTON_AT}Madvic
Please export and send relevant logs to us.
Log in to the SSH terminal.
cp -r /var/log/TOSDaemon.log /Volume1/public/
This worked for me as well, thank youTrussy wrote: ↑06 Jul 2022, 15:50 I’ve managed to figure it out.. I have 2 IP addresses in my network interface tab. (One for an internet connection, another directly to my PC)
I have issue with AppCenter.
TOS version: 5.0.166.00214.
When I open AppCenter I see blank pages with messages: "no valid data"
In TOSDaemon.log I has following errors:
How can I fixed up it?
2022/09/16 13:16:26 [Recovery] 2022/09/16 - 13:16:26 panic recovered:
runtime error: slice bounds out of range [13:0]
/work/go/go/src/runtime/panic.go:117 (0x45a05e)
/work/PKGS/Assembly/tosdeamon/service/tpk/app.go:269 (0xfb9031)
/work/PKGS/Assembly/tosdeamon/service/tpk/app.go:306 (0xfb91a8)
/work/PKGS/Assembly/tosdeamon/controller/AppController.go:141 (0x1119664)
/root/go-src/pkg/mod/gitlab.local/golibrary/resp@v1.0.7/resp.go:63 (0xd57db6)
/root/go-src/pkg/mod/gitlab.local/golibrary/resp@v1.0.7/resp.go:51 (0xd57bbd)
/root/go-src/pkg/mod/gitlab.local/golibrary/resp@v1.0.7/resp.go:62 (0xd57d35)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xd6e0aa)
/work/PKGS/Assembly/tosdeamon/middleware/middleware_model.go:164 (0xd6de26)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xd72ac1)
/work/PKGS/Assembly/tosdeamon/middleware/xcsrf/x-csrf-middleware.go:94 (0xd72aa8)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0x1491283)
/root/go-src/pkg/mod/gitlab.local/golibrary/safe@v1.0.4/safe.go:48 (0x149126c)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xd6b5de)
/root/go-src/pkg/mod/gitlab.local/golibrary/openssl@v0.0.0-20220520041315-7e4af9461ff4/openssl.go:157 (0xd6b5c5)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xd700d5)
/work/PKGS/Assembly/tosdeamon/middleware/middleware_model.go:366 (0xd700bc)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xd72863)
/work/PKGS/Assembly/tosdeamon/middleware/xcsrf/x-csrf-middleware.go:68 (0xd7284a)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xd702be)
/work/PKGS/Assembly/tosdeamon/middleware/middleware_model.go:385 (0xd702aa)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xb1217a)
/work/PKGS/Assembly/tosdeamon/middleware/logger/logger.go:110 (0xb12157)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xaa0901)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/recovery.go:101 (0xaa08ec)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/context.go:173 (0xa9f750)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/gin.go:616 (0xa9f3b8)
/root/go-src/pkg/mod/github.com/gin-gonic/gin@v1.8.1/gin.go:572 (0xa9eefc)
/work/go/go/src/net/http/server.go:2916 (0x89f21a)
/work/go/go/src/net/http/server.go:1966 (0x89a216)
/work/go/go/src/runtime/asm_amd64.s:1571 (0x48c460)
{L_BUTTON_AT}yurok712
Log in SSH terminal.
Execute the following command. (Replace admin with the username logged in to TOS)
rm -rf /etc/tos/config/admin/*
