Unable to get OneDrive Sync App to Sync
darryliswright
Post by darryliswright »
Hello All,
I've been trying, unsuccessfully, for the last 5hrs to get OneDrive Sync app to connect to my OneDrive account. I continue to get Operation Failed error message. I do not know what the problem is or where to start.
Also, the names I've created for the connections are no longer visible and the app continues to tell me that ones I've used are taken and cannot be used, but the connection cannot even be established.
Some help would be appreciated.
Many thanks.
Garyxxclub
Re: Unable to get OneDrive Sync App to Sync
Post by Garyxxclub »
same problem here...
"Operation failed" Error Message...
Can't sync my One drive account...
On the Microsoft account the TM App has all the permissions...
Gary
Thank you for your report, we will verify it soon.
21alpha
Post by 21alpha »
same issues as above
Ive even uninstalled and re-installed onedrive on my F2-421 and get to the page where it states to add permissions (which I did) then receive the "operation failed" message.
21alpha
Post by 21alpha »
onedrive connection and sync works in Cloudsync 2.2.4 on TOS 5
