Map Remote Network Drive on TerraMaster NAS
raders
Post by raders »
I`m using the F2-210 and is currently located on a different isp to the one i`m currently connected too, as Im using the "Remote Access" feature.
I`m wondering if it would be possible to map a network drive and connect remotely using Net drive, web drive or another app/software pre-installed on the NAS?
TMS
Re: Map Remote Network Drive on TerraMaster NAS
Post by TMS »
Where do you need to map the network drive?
raders
Post by raders »
From a TOS file explorer file, too a network drive on windows.
TMS
Post by TMS »
Mapping generally needs to be used with vpn, you can also use winscp software (other tools) and use ftp protocol to connect.
Return to “Others”
